- Nov 25, 2015
- 8,314
why did you use the spray. Liquid just pour it on and brush it out. but whatever. I had good results with it.
Better than the other strippers.
Mixed with water and cornstarch to make a paste.Has any used drain cleaner.
I have use that past. Works great they use same chemicals in transmission hot tanks too.
Instant Power Crystal Lye Drain Cleaner 1650 - The Home Depot
Instant Power Crystal Lye Drain Opener quickly and effectively clears clogged drains. Powerful 100% Lye formula creates heat to melt and dissolve grease, hair, soap, scum, and other drain clogging material.www.homedepot.com
Dave
I left a rag with dot3 on a painted floor in the shop. The next day I had a clean to bare concrete spot!!If I ever run out, dot3 is also great at stripping paint
My casting has multiple bronze bushings so sodium hydroxide isn’t recommended, even at 5% concentration. Not fun to work with either, I used to make it too, in electrolytic cells 100 feet long and 15 feet square. It will eat skin, leather, nearly everything organic.Has any used drain cleaner.
Dave
Yeah, that's an interesting one. I'll have to try it on the next project. I'm guessing with the formic acid that it smells rank. Not sure why it's needed in the formula exactly. I haven't played with n-methyl pyrrolidone, but it seems to be pretty versatile. Worth a try.Well I can confirm the Sunnyside stuff is melting the 66 year old paint off of my mill. Citrus stuff did nothing, Jasco did a little, but this stuff is bubbling it off. I’m guessing these new strippers are only good with certain types of paint chemistry. So trial and error until you find one that works.
I just weather in tank like 5 gallon bucket.Mixed with water and cornstarch to make a paste.
