- Oct 13, 2014
- 6,822
I had a close call with an acetylene torch. Back in the late 90's I was part of a team, renovating a floor of the Knickerbocker Club in NYC. in one of the rooms there was a heavy piece of steel angle protruding a few inches from the concrete floor, in a place that was formerly a wall but now was to be open space. It was about 6"x4" and a ½" thick, someone proposed grinding it off but that would have taken a while and we only had one cutoff disc. Earlier, I had noticed a Oxy-Acetylene rig in the clubs shop, so I offered to torch it off. The club's head of maintenance brought up the torch rig which appeared older but hardly, if ever used. It was already set up for cutting so I just checked the connections and started cutting the steel. I got most of it off and was going back to knock off a bit that was still sticking out. Suddenly there was a loud whistling sound and flames were shooting out from the base of the torch, one of the most heart-stopping moments in my life! I immediately shut the tank valve and it stoped. Upon examination it there were plastic seal washers where the hoses connected to the torch, the one on the acetylene side was split. I had never seen these before, I doubt they belonged there. Maintenance guy said the torch had been there when he was hired about 15 years prior and that he had never seen anyone use it. I don't know if it was a flashback or the leaking gas simply ignited from the torch. Either way, it was a very learned lesson.
