- Dec 18, 2019
- 6,472
I have an OXA boring bar holder that I'd like to modify the design. Just bought a 3/8" QCBI carbide boring bar any I'm a bit leary about using the stock 250-004 holder. One day I'd like to get a 1/2" bar, and I know I wouldn't trust the holder with the bar. The 250-004 clamps the bar in two little spots which isn't good. It would put a very high local pressure on the carbide bar. In the picture below, the bright edge protrudes into the 1/2" bore, thereby clamping the bar.
The only way I can see to fix this is 1) make my own holder, or 2) modify what I have.
Under #2, my options are limited. The holes are counter bored on only one side. The bottom hole is 9 mm ID, the top is clearance for 5 mm with a counter bore.
One thing I could do is: make a lipped threaded bushing to fit in the backside, out of 1/2" hex stock. By milling a 1/2" slot, say 1/8" deep, on the bottom, it would prevent the nut from rotating. Then I could run a slitting saw down the side. The holder may not quite long enough to handle 3 screws, especially if I mill the 1/2" slots, as I'd only have 0.15" of steel between the 1/2" nuts. Are two 5 mm bolts enough to hold the boring bar tightly?
Are these offshore tool holders hardened? Do I need carbide cutters?
For the 3/8" bar I'll sleeve it, as the 250-004 is bored at 1/2". It came with a crude 3/8" sleeve made of some weird, poorly machined steel. Might make another one, just because.
Does this seem like a reasonable modification, or do you see disaster ahead? This is a spare holder, I have two of them.
