WARNING: Long, tedious reply to follow... LOL
On some respects, I agree with you Mark, on others, I don't have the knowledge and/or background to agree or disagree.
I know my cell phone service is worse since they went digital all the time touting how much better it was going be. All the while knowing it wouldn't just made it more profitable being able to route more data and calls through the same infrastructure.
As far as my interest goes, I've been intrigued with open source electronic options like Arduino and Rasberry Pi. They have their limitations (for now), but it does allow a means for backyard inventors/tinkerers to enter the digital age/market on the cheap. I see more and better inovation coming from the small guys and gals out there than most anything coming from Corperate America these days. Once proven, they are more than happy to come steal it with big time lawyers and loopholes, but I can see a day coming where that will end as well.
As a new hobbyist in the metalworking field, I like learning on the manual machines I have, but with the limited time I have to play, having a DRO to help me track position and not lose count of turns is a big plus.
I chose going with Yuriy's Touch DRO simply for cost. I end up with a 3 axis DRO on my mill and a 2 axis on the lathe for less than half the price of a single dedicated 3 axis kit from places like DROPRO's. The smaller scales are much easier to fit and mount as well.
I don't need a wireless display, but don't know enough about them to match a dedicated display. With the wireless connection to my tablet and/or smart phone, I can use either with my mill or lathe. I can update software simply by a touch of a button so to speak. A display is easily replaced as well with a new tablet or phone just by downloading the App. Fuctionality is also being added all the time. When I first ran into it, the Touch DRO was fairly basic. It now has a fully funtional and customizable toolbox for your various tooling that can be updated easily. They've also added a Tach option though it's currently in the infancy stage of developement.
Memory space is only limited by the amount of expansion memory your device can handle. My tablet, for instance, can handle a 32 Gig flash card on top of the 16 Gig internal memory. Something not possible with any of the dedicated DRO system I've seen. Having the mobile display will also allow me to look at saved steps for projects and change/improve them anytime anywhere.
I know it's not the best DRO or scales out there, but with the large following and open source software and hardware, it may well be the best one out there in the future.
The main reason I went with the Arduino vs MSP was simply the fact I've wanted to learn to use it for other projects and ideas I have. Seemed like a sensible thing at the time just didn't know that the new iGaging Absolute scales I bought were not compatible with the system as it currently sits.
The amin issdue, as I see it, is that most of those using it have the older scales and aren't currently interested in making the new Absolute scales compatible. I figured why not get an oscilloscope or logic analyzer to connect to my scales and get the data needed for the changes needed for the hardware and programming. From what I've read, there are plenty of people out there in the Arduino community quite willing to help with this, but seems none are willing to spend the money on the scales to do the hack.
I posed the question here because I know basically nothing about O'scopes or Logic Analyzers, but knew from my time on this forum that there were many such as yourself, who do have the knowledge and are more than willing to share/teach people like me.
In another thread (
http://www.hobby-machinist.com/threads/does-it-exists-3-axis-display-4-igaging-dro.37555/page-2), I posted this that I found about the compatibility of the new iGaging Absolute DRO scales:
Is the Android DRO compatible with the serial output of the new igaging "ABSOLUTE" series ? :
http://www.igagingstore.com/38-Absolute-Digital-Readout-DRO-Stainless-Steel-S-p/205483.htm
Reply
Replies
Yuriy KrushelnytskiyAugust 3, 2014 at 9:45 PM
I don't know; haven't had a chance to play with the new model.
Nathan WrightNovember 18, 2014 at 10:07 PM
Short answer: no.
At a minimum, the Absolute DRO has a 2KHz clock. But, changing the clock freq isn't enough.
The data line is severely attenuated with a 5.6K PD resistor. The original display unit has a 100K PU resistor, so this will require a schematic change to match.
Have not had a chance to look at the data on the logic analyzer to confirm if it is still 21-bit.
(There also appears to be a pull up on pin 4 of the Mini-USB. Looks to be a basic connection check - the control unit stops sending the clock if that pull up is removed. Looks like this can be ignored.)
Will investigate further and post an update as time permits.
All this may mean something to you, but to me it just says the scales I bought and installed won't work for the DRO I hoped to have and the Arduino PLC's and various electronic components I bought will sit on the shelf until someone does figure it out.
WHEW !!!
