- Sep 24, 2010
- 3,096
What size tooling are most folks using the majority of in their 9X machines.. I have 1/4, 8MM, 5/16,and 3/8ths bits and holders available and quite a bit of indexable small tooling from my 7X10. If I can continue to use the smaller tool holders in the larger lathe it will save me a good chunk of change in retooling costs for the 9X. I think I even have a couple of 1/2 tools too. I realize that the smaller bits may be flimsier and subject to more chatter, but is there any reason not to use it. I have a QCTP on both machines so I can easily adjust the tool height to get it perfectly centered. Any caveats or reasons I cant use what I already have while I am building up my larger tooling selection? And what size would you consider to be max for most projects and materials. Thanks in advance!!!
Bob
Bob
