- Dec 24, 2020
- 1,056
Not entirely true when you consider that Logan is still selling new parts for their vintage machines. Not every part is available, but most are...not always cheap, but at least available. Used SB parts are definitely the most common, but for wear items I'd rather buy new when possible.Too many photos for me to scrutinize all of them so I will just give some general advice.
You absolutely want a quick change gear box.
Not many of those small lathes were run day in, day out so wear - though you should check for it closely is not likely to be a huge issue.
Absolutely get a lathe with roller bearings in the spindle. Forget those that have bronze or babbitt bearings.
They made a gazillion of those South Bends so parts and/or accessories will be much easier to find than for other brands.
Buy the biggest lathe you have room for and the ability to move.
Buying an older lathe that needs a bit of work - but not a lot of work - allows a guy to learn how the machine works before he learns how to make things on it.
I would ten times rather see a guy buy an older lathe from the US - or ANY of the nations we are allied with than a brand new poj from China.
Clausing also still sells a lot of new parts for their vintage lathes, but not as many as Logan. I've owned all three brands and the edge goes to Logan for parts availability, by a long shot. They even still supply things like steady rests, follow rests and complete taper attachments...pretty surprising really.
