- Feb 8, 2014
- 11,145
I just about have my servo press project out the door https://www.hobby-machinist.com/threads/servo-punch-press.72601/
But today I ran into a small problem. The system was designed to mount the electrical enclosure inside the stand. Well there is not enough clearance for the press mounting bolt heads That's what happens when you make a design change without checking everything.
Here is the problem.
And a little wider view.
The good news is that I figured out a simple workaround.
More later.......
More later.......
