- Jan 31, 2016
- 11,478
Well then , time for an " upgrade " !I wish.
Everything is below grade here.
But this is a v-bed right? Did they come that size in round bed as well? How accurate is those round bed models and how do they wear? Does it have a tipe of slot at the bottom of the bed to keep everything on top of the bed? I could not propperly check it out when I was there,no time.and here's it's BIG brother
View attachment 386357View attachment 386358View attachment 386359Lathe, 'Drummond' 26" x 10ft. 4¼" Spdl. bore, taper-turn, V.Good! | eBay
(Engine lathe, 10ft.x 26" large cap. btween ctrs): 10ft. Sold as is, but we warrant this lathe to be free of latent defects. Capacity, diam. swing: 26" (635mm). Swing over cross-slide: 15". Spindle bore: 4-¼ in.www.ebay.com
and they have this picture:The heart of the lathe was the heavy, round, 3" diameter cast-iron bed, ground to within 1/1000" on an American Norton cylindrical grinder and formed with a bevelled slot along its underside to locate the tailstock and carriage. The leadscrew passed through the centre of the bed
Huh! The bed is keyed! But, -why- would you want to adjust the carriage angle WRT the bed THAT far???
With its top formed as a boring table, the "saddle" assembly could be partially rotated round the bed - which movement had the effect of altering the height of the table in relation to the spindle centre line. It was thus possible to make vertical adjustments when setting work on the boring table and make making minor changes to the setting of the height and angle of turning and milling cutters, etc. This versatility of movement had some interesting consequences, it even being possible to mount and rebore the (detachable) 4-cylinder block from an Austin 7
