- Apr 29, 2019
- 2,059
It sounds like your machine may be bad enough that you do not need a "precision" straight edge to be able to see it.
Go to the store and look at metal meter rulers, the wider and the thicker the better. Take the ones that are there and place them edge to edge and hold up to the light the less light the closer they match. when you find a good match turn one of them over and check again. to see if they are still good. then flip the first one to see if it is still good. This will not get you precision straight edges but it will get you the to straightest ones in the store. Buy both of them. Mark one as a standard and put it away and only use it for checking the one you will use for things. Back when I was starting out this was as close as I could afford to getting a precision straight edge. Once you actually start checking them it is surprising just how far out some of them are.
To properly fix it you will need some true precision tools.
