- Jul 17, 2013
- 99
Ok, so I'm working on a project..
I turned two pieces of some 304 SS down to 0.40".
Holding the work in a 3 jaw chuck.
I then center drilled and then drilled one of the pieces, using the tailstock chuck progressively up to an I drill, then tapped to 5/16-24.
I then turned the end of the other down to .3125" and used a die to thread to 5/16-24.
When I attempted to thread them into each other, they are not centered on each other. Not even close.
I started looking at them closer and it looks like my tailstock may be out of alignment, as the hole I drilled is not centered in the parts. One is easily more off center than the other.
Does this sound like a tailstock alignment issue or is something else going on as well?
