While going through the drawers of my Grandfather's old lathe I found a strange drill bit. It is a 2 flute twist drill at first glance, but while looking at the tip to check the sharpness it looked really strange. First, the tip is flat. For a bit that mic's at 0.6975" the flat tip is around 1/8" in diameter...and it looks ground, not hammered or burned off. Second one flute is MUCH bigger than the other, both in depth and width.
The picture is a little dark, but the flutes are obvious.
What is this for?
What is this for?
