- Sep 11, 2015
- 293
I need to make an internal threading tool for a project I'm working on. My current internal threading tool I ground from 1/2" HSS is just shy of reaching to where I need to thread. So my thought was to make one from some 1/2" o1 tool steel. Drill a hole on one end to hold a tiny HSS bit hanging off the side. With a set screw holding the bit of course.
Does the o1 need to be hardened or can I just use it as is? My thoughts say harden it to reduce flex in the shank. But it's going to be used on aluminum, at least for this project. So, to harden or not to harden. That is the question.
