I am wanting to shave an 1/8 inch thickness off the ends of 1 inch thick solid rods - I'm trying to make plugs to fit into chrome molly tubing - I don't really know how to describe in words what I want to do, but here goes: I want to stretch a motorcycle frame - so I'll cut the down tube and place a 6" piece of solid rod (same diameter as frame) between the two pieces (thereby extending the frame) - I was hoping to reduce both ends of the solid rod so that they will insert into the frame tubes at least 2 inches (I could then drill and plug weld).
I assume I will need a lathe to do this... if so what is the best type (model) or style of machine to do this? Are there affordable lathes available for the "backyard" machinist? I realize I could take my projects to the Machine Shop - but here I have an excuse to buy some new or used equipment (you know what I mean).
Any help would be appreciated.
Ed
Ed
