- Dec 26, 2015
- 2,079
This tach is designed to allow for any number of hall effect pulses to represent one revolution. On my mill, I have four magnets on the spindle, equally spaced, and at (for example) 60 RPM, the tach is seeing 4 pulses per revolution of the spindle, and the tach needs to know that ther are 4 pulses per RPM to be able to calculate the actual speed of the spindle. On my lathe, I have 8 magnets because I often tap at 8-20 RPM using the Jog function, and want a timely and accurate representation of that speed.But why would you need to tell the tach how many pulses per revolution from the Hall effect sensor.
In some applications, 1 pulse per revolution is sufficient accuracy, whereas in other applications 2 or 5 or 10 might be appropriate. Consider this tach on a spindle shaper where the spindle speed never falls below 1,000 RPM. In that situation, one magnet pulse per revolution is sufficient to give a timely and accurate reading. Now consider a situation where this tach is used to accurately measure the speed of a slow turning element (the X-axis lead screw for instance) rotating at 2 RPM (not uncommon). In that scenario, with only 1 magnet, the tach is seeing only 2 pulses per minute and it won't be able to accurately resolve the RPM in less than 1.5 minutes. In that application putting 10 magnets on the spindle at 2 RPM would provide the tach with 20 pulses per revolution, and it could then accurately determine the speed after 3 pulses or in ~5 seconds. Now consider the low slow spindle speed is fluctuating - you'd want even more pulses per revolution in order to have a timely and accurate reading of the RPM at any instant. In all these situations, the tach needs to know the number of magnetic sensor pulses per revolution in order to calculate the true RPM.
Does that help?
