- Mar 26, 2018
- 8,443
I don’t see any machine. I don’t do Facebook, is that why?Here is an example of what "sub $600" gets you in my area. The seller started out at $2000.
Rusted RF30 ACRA clone
Some healthy girls.not missing much..............
I don’t do any so called social media. My suspicion of it was totally born out by the recent insider whistleblower leak of internal docs. Without FacePlant and it’s associated apps the world would be a much saner place. And that’s no exaggeration and their internal memos bear this out. It is far more dangerous than the masses who are addicted to its fomenting of outrage can come to grips with.No can see, don’t do Face Plant.
Agree. As a possible addition to the original post, after working on gibs and the follower nuts to take out the slop, I have come to believe that the remaining slop will respond to the addition of some shims outside of the bearings. I will report success.Not adding anything really, but my round column mill has been handily making me feel silly for a few weeks now. I quit bothering with speed changes and just run it at 380 or thereabouts. I also indicate off the head if I have to raise or lower. It's actually not a big deal at all. And say nothing of DOC... this thing is fine with heavy ish cuts in steel and aluminum. I bought a knee mill just by chance, and I'm using the rc mill to make things for it. It's much better than I thought. It just needed a more confident user at the handwheels I guess.
Some more on this mill. As, perhaps, you know, the feed shaft followers on this mill can be touched up with an adjustment in the nut itself. Pretty easy to get to the X axis nut. Y axis nut is harder unless a base is designed with an opening in the top surface that allows access to the Y nut. (Planned on my new base) But tightening these nuts ignores play in the shafts created by sloppiness in the design of the end bearings and end bearing journals.Yes I see them. I will likely use some metal casters. Prolly buy them from Harbor Freight. Kind of anxious to get started now that I have seen yours. Thanks.
So I made two shims from brass stock. The first went between the handwheel base and the dial. This moved the dial closer to the bearing journal to help close the gap. The second shim went between the bearing rider and the bearing. This is actually the surface which holds everything in place.Some more on this mill. As, perhaps, you know, the feed shaft followers on this mill can be touched up with an adjustment in the nut itself. Pretty easy to get to the X axis nut. Y axis nut is harder unless a base is designed with an opening in the top surface that allows access to the Y nut. (Planned on my new base) But tightening these nuts ignores play in the shafts created by sloppiness in the design of the end bearings and end bearing journals.
I tightened up the follower nuts as best I could but still had about ten thousandths backlash in the table movement. I detected this as I turns to right X axis handwheel clockwise until the table began to move. Then I turned it the opposite direction and was able to move the handwheel about ten thousandths registered on the handwheel dial. First photo is of the moved handwheel. Almost exactly ten thousands.
