I've had a RongFu RF31 mill for several years. Mostly used it for precision drilling (has a DRO). I have a power feed on X. But when it ocmes to actual milling, I'm a complete novice. I understand feeds and speeds, chipload, etc. How to calculate them anyway. I've looked to S&F calculators, like the Gwizard, but the results I get with it never seem right. It seems to be oriented toward max speed for production CNC environments, but it says if I don't go as fast as it says I'll suffer from rubbing and tool dulling.
My machine is listed as 500-3000 rpm. My power feed will probably go 20ipm full on if I remember right. But it would be good to know speeds I could turn by hand.
Can someone help me get up to speed no pun intended. I have a couple of examples I could use help with, I'll start with this one:
I figure at my lower speeds, cutting alu or plastic most of the time, HSS is better than carbide, and most of my tooling is HSS.
Say I want to mill a .125" slot in 6061 aluminum .125 deep. Normal flat bottom endmill.
For this setup, can someone help me arrive at a decent F&S that won't break the tool? Ideally get max depth of cut. And, forgot to say, what about # of flutes. I need to get some new smaller mills as I've broken the ones I have so what's best for my machine, 2, 3, 4 flute?
