Non geared rotary table
jwmay
H-M Supporter - Gold Member
Dec 3, 2017
1,913
Next project that's been following me around for years is this rotary table, based off of Harold Halls design. The main body of it was made from a very large chunk of what I think is D2. It was miserable to machine. Burnt up a half dozen HSS edges before I went to carbide. At any rate, when I got just about to what you're looking at, I messed something up and stuck all this in a drawer.
I decided today, that it's waited long enough. So after some studying of the drawings, and watching the YouTube video, and searching for the book I got the plans from, I realized that I also missed a three hole pattern in the center of the table itself. So it's set up in the mill ready for me to fix the first overlooked mistake I made all those years ago.
My plan is to drill and tap three or four holes in this to bolt an aluminum plate with a grid of threaded holes in it. I say three or four holes, because I expect this metal to be completely disagreeable. I should mention that Mr. Hall warned against using unknown metals while learning to machine. And so, this is my just desserts.
If you're curious, this is the last part I failed to machine correctly. This is what landed the whole project in a drawer for years...lol
Yes, mystery metal can be just awful to work with, even if it saves money it wastes time
Here is the table mine is modeled after. Tee slots aren't really an option due to the miserable mystery metal I used.
mistakes are normal. how you fix them is what makes you a craftsman.
sometimes I do the same, and put the project away for a while..
glad you picked it up again. Most of the time you can fix it.
I've plugged holes, and you can't see them, I've filled slots , by keying them as a t slot.. And sometimes, I've left the scars as a reminder, or not worth worry about.
Well wouldn't you know it! I messed it up again! Luckily, a shim saved the day. D07F46D4-4543-4E99-8D70-C6185CA585A0.jpeg7E3C54E2-25D3-49F6-BC2C-05A638550CAC.jpeg
Another thing I tried to do, but didn't quite get right was this. I attempted to just countersink the bolt pattern instead of counter boring. After realizing it was going to fail, I counter bored the other two. So it doesn't look very nice, but I'm ok with it. 0EE08D69-4B21-49D5-9B87-4A72B5DDCF21.jpeg
Lastly, I needed to make a space for a tapered nut to fit into the slot at the base. There will be a couple hard stops that get mounted here. I now have to make the tapered nuts.
