No volt release switch options
guy2600
H-M Supporter - Silver Member
Feb 16, 2024
2
Hi,
Looking for a no volt release switch with forward and reverse. Do these exist? Having a hard time finding one. Thanks!
Alternatively, if this function is easier/cheaper to do with multiple components, that would work too.
Explain what you mean by no volt release switch, not familiar with the nomenclature, if mainly you want a fwd/rev/off switch, what is wrong with a drum switch?
A magnetic starter wired to start and stop buttons (three wire control) will "release" when voltage drops out. Reverse will require another switch.
Apparently, the NV Release switch is a magnetic switch that is commonly used for E Stop. Once released, it requires a separate switch to reactivate. I am not aware of one that incorporates forward and reverse as well. My machines have separate switch for forward and reverse. Here is the switch that I used for forward and reverse. It is configurable for whatever type motor you are using.
