I like the spray pattern these make. I ran at 30psi for testing with water and it worked great. I can't test it on a machine as my lathe isn't here yet, but it seems like a good option with a wide range of adjustment.
So my thinking was both regulated and the 2 valve. The same way a conversion HVLP sprayer has regulated air, plus a air adjustment screw to fine tune the volume, seems like you can take high pressure dial it in close, and adjust it even finer. A ball valve for on and off seems like a good idea too.If regulated air pressure is provided to the mist system, then the next thing needed is a needle valve for the water in. That is a very important part of the system because it needs fine adjustments. Before I purchased those twin needle sprayers, I considered getting a inline needle valve form a OS Max engine because they could adjust flow rates pretty well. I ended up not doing that because those things are in the neighborhood of around $40 each. But, if you already have enough air flow for the system to draw water, then the only thing left is something to finely regulate that water flow and that's pretty much it.
