Newbie with Emco Compact 8 /w Mill head
Well, I made something with my lathe : alu PCB holder with a magnet underneath it. The finish is nice and I want more of this by grinding a HSS tool for turning and giving better finishes on aluminum.
I am not sure if the ISO 10 oil is the right one for lubing the rest of my lathe alongside my way oil, any suggestions ?
Lately, I have been noticing that my lathe vibrates excessively at 1000 RPM. That's normal ?
Looks like you have some chatter marks on top, Fermic.
No, the lathe should not vibrate at 1,000 rpm. Is it belt tension or an old, worn belt?
With the old belt, it feels loose at A and C pulleys. Requiring to use the tension arm. It vibrates loudly too.
For the new belt ( Gates brand ) 5M590, it can be attached to the A and C pulley and feels snug. Without the tension arm down, there less vibration but as I drop down the arm it also does vibrate too.
Here's pic of my old belt, handling it leaves dust in my fingers :
Are the pulleys co-planar? That is, do the grooves line up?
At my visual inspection, they are co-planar on A and B to C pulleys. Grooves does line up, I don't find any belt twists.
Something to note, the belt on the pulley B does make the lathe vibrate and I don't have a new belt to replace it.
I am not too sure about the main spindle bearings, my hand spin test somewhat give 1-2 turns but if I hand spin faster then I get more than 2 turns.
Try tightening up on the preload; you want about 1 to 1.5 turns max with a hard spin.
Might be time to change that other belt?
Small update :
I managed to tighten the chuck and I got from hard spin test at 1.8 turns, but I broke my 3D printed wrench when trying to tighten it once more.
Still, there's vibrations starting 1000 RPM
Also I made another PCB Holder but this time I damaged 2 HSS pre-cut bits and I need some tips or layouts to regrind mine back in shape. These pre-cut HSS toolbits are "8 pc. HSS 5/16" Mini Tool Set" from Grizzly
One right-hand offset and I tried to regrind with my bench, I also screwed it up. And one turning tool that just stop cutting aluminum.
My broken 3D printed hook spanner I designed to save the cost of getting the metal one :
1.8 revs is a bit loose but should be okay for now.
Show us your tool and we might be able to help. Have a look at this thread so you can become familiar with the nomenclature first.
Here these pictures, it wasn't easy getting close up shots with my phone.
IMG_20210303_000357.jpgIMG_20210303_000428.jpgIMG_20210303_001901.jpgIMG_20210303_001934.jpgIMG_20210303_002013.jpgIMG_20210303_002447.jpg
