I might already have my answer. Sounds like I would have to machine an adapter plate to fit between, which I was hoping to avoid. So... it seems like the better option would be to look at rotary tables that have 3/6 slots and mount a chuck with front mounting bolts. That leaves me looking at Yuasa and South Bend rotary tables, with a Gator 6-jaw chuck. Any thoughts on these makes?
I'm machining blackwood and rosewood to make wooden Irish flutes. I'll be using a small RT in the vertical position with a tailstock. A 4-inch table would work, but I've got room on the milling machine for a 6-inch, and Tormach has a 6-inch tailstock that will accept a mt1 bullnose live center. I'll be machining while turning the RT to mill out wooden blocks for keys. From what I've read, seems the RT is the right tool for the job, verses dividing heads, indexers, etc. And the 6-jaw chuck might be obvious at this point, to reduce pressure on the thin wood.
-Jay
