So imagine a 8" x 1" piece of steel 3/16" thick. I need a 1/4" hole centered 1/2" from each end and a 3/8" wide slot starting 1" from each end. I made this by first squaring up the edges of the material with a 3/4" end mill, then using the parallels, I clamped it in the vise along the long edges.
I used a 1/4" drill bit to drill the holes on the ends and a series of holes 3/8" apart where the slot will be. I then enlarged the holes with a 3/8" drill bit. Then I took a 3/16" end mill and went down to center to connect all the holes. Finally, I used a 3/8" end mill to make one continuous smooth slot.
Is this overkill? Could I have started with a 3/8" hole and used that as the starting point for my end mill and cut my slot with the 3/8" end mill in one pass?
I also have a question about climb vs conventional milling. I understand that conventional milling is preferred, but if I'm cutting a slot straight through the material, it seems I am performing climb and conventional milling at the same time. My workpiece is moving to the right. My end mill is turning clockwise. It's cutting on both the ingoing and outgoing part of it's rotation if it's cutting a slot in virgin material, right?
