I recently bought a 745 that needs some freshening up, as it sat outside under a covered carport for sometime before i got it. and i believed it spent most of its life in the maintenance department of oak farms dairy or so i was told
x axis is buttery smooth but i still need to pull the table to check out the saddle which y axis is very stiff. the z axis shaft was also broken at some point and will need some attention.
*any help pulling the power feed gears off the lead screw, as the casting is too close to the back of the gear to get a traditional gear puller behind it?
*ive ordered a n-03 socket for the lock nuts on the left hand side, i included a pic for the next guy as i wasn't familar with them
*a pic of the broken z shaft that i had to drill to start disassembly
*any idea where the set screw is that holds in the z shaft? i may have to wait til i get the table and saddle off and see if i can access it from the top
i realize these are pretty rookie questions, but i hadn't been able to find them addressed so far, and any insight will be greatly appreciated
