- Oct 17, 2018
- 925
I've parted out two lathes and restored mine. You will likely get lots of money parting it out, But, where's the fun in that? It takes forever and you have to deal with shipping and fees. PITA.
I say restore it. You seem to have the time and desire. There are motor frames on Ebay all the time. Parts for these are relatively cheap. You could even buy a beat up one and use it for parts. That's what I did. I learned a lot taking mine apart and putting it back together.
Cleaning it up will be tough in an apartment. I got a big plastic bin and used that as a parts tank. I made a box that fit the ways and lined it with plastic. I soaked it outside in Simple Green and got it fairly clean. I used a pressure washer also. I have a garage and power tools so I can make stuff, like wood boxes to soak ways. That will be your main challenge in an apartment. Everything else fits in a big plastic bin. Well, the smell and mess might be an issue!
Getting the spindle apart requires some pipe and a long screw. I was able to cut down some large diameter steel pipe because I have a metal-cutting bandsaw. It helps to have a workbench for all this as well. Have someplace to store all the parts as you disassemble and clean them. I cleaned, primed and painted them with rattle can paint right away to deter rust. Again, that's tough in an apt.
