- Dec 25, 2011
- 10,526
And you will need an arbor press with a throat deep enough to hold the apron part of the carriage in order to install the replacement M6-29 lever. And be sure that you match-mark the old M6-29 Lever and the M6-38 Cam which you will reuse. The lever will fit the cam four ways, only two of which will work. Murphy's Law says that if you try to put the new lever on the way that you think it should go, you will be wrong.
And I would use a Groove Pin for a retainer instead of a small set screw. The set screw will eventually work loose.
On whether or not you could machine the M6-13 into an M6-13A, the answer is "yes, but". The M6-9 Carriage did not change and the M6-38 Cam did not change so the tapped holes and therefore the OD of the M6-13 did not change. However, the part is available and it would be more than a simple milling job to make the M6-13A out of the M6-13. If you had to, you could. But I wouldn't. The M6-13A was used on every Atlas 6" made from about 1940 up through 1980 or 81. Plus it is probably still available from Clausing. So finding one should be no problem.
