- Dec 25, 2011
- 10,513
I should add, since someone may mention them, that there are several ways to build a nut and screw that have zero or near-zero backlash. However, after months or years of use, the cross feed screw will be more worn in the region where you do the most work and in areas where you do little or no work, there will be little or no wear. So if you adjust the nut for near zero backlash in the well-worn area, it will jam or freeze up if you try to move the cross slide into the area where you never work. So you are better off learning how to use the lathe in such a way that back lash doesn't matter.
