- Apr 23, 2011
- 2,476
I picked it up from a small slipway that was shut down, so it may have been used for diving air. But I live in croc country so I dont know that I would be to keen on diving in the creeks around here.
--> Martin, pretty sure its not off an aircraft. Its way to heavy, All cast iron. It would run close to 80 kg.
--> FLguy, any hints as to why you guess that? I'm open to any suggestions for maker.
--> FOMOGO, whereabouts did you find that pic? I would like to see a larger image if I could. And what did you type in for your search?
I was hoping to use it for shop air to replace my tired old twin cylinder, but seeing as it is such a HP unit it may be to small in the CFM to run air tools.
Cheers Phil
Cheers Phil
