- Apr 30, 2015
- 11,333
Myself, I always use oil when I cut steel. Dry for aluminum though.
Mark
Mark
Pic 2 looks kinda crooked to me, is blade 90 to fixed vice jaw ?
Mark
If it was in the first few minutes of cutting andy you were conditioning the blade (that is on the slowest setting) when it happened, I'd take it back.
- First I'd check the saw in every aspect and even try a carbon steel blade for a good result and then complain. I've never had a bad blade, but I've heard fro a few guys that claim to have see one or 2.
The top end when you lift it will it wiggle on the hinge pin ? That would let it shear teeth off. Rebuild the cylinder and use it with slow feed and try slowing the blade down . Or maybe the blade itself is defective. Tooth area to hard or not uniform throughout.
