- Dec 18, 2019
- 6,464
Post #15 on tailstock says video unavailable, so it will be tough to watch. Bad link?
Must be - here is a fresh link:
Yeah, that doesn't look so hot. Can you get a close up still of the pyramidal notch? It seems not too bad. Other side is not finished, or finished poorly. Not sure how much you should take off though. If finished smooth, that would be a lot of material! Lets just say, that does not look like a "factory first". (As opposed to a second.)Must be - here is a fresh link:
The new link works.I can see the videos here in the forums - is that one working now? I see that WobblyHand saw it - I will try to get some closeup shots in a bit.
And the second box just arrived! Even the little toolbox is intact and, as expected, the 4 jaw chuck is self centering. That is something I just don't understand - perhaps there is a use case such as drilling small square plates. Actually, I need to modify the hole in my QCTP base so that might just work for a boring operation.
