Well I finally bit the bullet and upgraded my mill from a column to a turret.
Should have done this in the first place. I found the King PDM 30 Mill/Drill just wasn't heavy or accurate enough.So now I have a Mill/Drill for sale if anyone is interested.
Here's the spec's and some pictures. Its a King 942VS-6-NF Turret Mill.
View attachment 60571View attachment 60572View attachment 60573
3 HP 2 speeds, variable speed drive
Turret head swivels 360°
Meehanite cast-iron and chrome ways
Bedways are hardened and precision ground
Centralized lubrication system
3 speed power down feed
Spindle taper R-8
Quill power feed 0.0015", 0.003", 0.006"
Max. spindle distance to table 19"
Spindle distance to column 6 3/4” x 19”
Table size
9” x 42”
Speeds (RPM)
(70-500 / 600-4200)
Table travel
30”
Saddle travel
12”
Knee travel
16”
Max. longitudinal travel
24"
Cross travel
13 3/8"
Quill travel
5”
Ram mouvement
12"
Size of T-slot on table
5/8”
Motor
22 Amp.
Voltage
220V, 1 phase, 60 Hz
Assembled dimensions (LxWxH)/weight
58” x 57” x 85” / 2,000 lbs
Package dimensions (LxWxH)/weight
66-1/4” x 54-1/4” x 73-1/8” / 2,400 lbs
Spindle taper R-8
Table size
9” x 42”
Speeds (RPM)
(70-500 / 600-4200)
Table travel
30”
Saddle travel
12”
Knee travel
16”
24"
Cross travel
13 3/8"
Quill travel
5”
Ram mouvement
12"
5/8”
Motor
22 Amp.
Voltage
