At the beginning of this year I moved from a rented house with a 1500sqft garage/shop area to my own house with a 2 car garage and 2000sqft basement. Previously I mostly did fab and automotive work, but have always wanted to get into machining. Spent a little time behind a lathe and mill in college.
Now with more room I am able to start expanding my capabilities. Shortly before I moved I found a guy on CL with a MaxNC 10 mill. He had replaced the controller with a LinuxCNC/Probotix setup and several other upgrades in the name of stability. Some horse trading later and it followed me home. I waited to set it up until after I moved. Here it is in it's temporary resting place:
The cabinet was formerly a bagging cabinet from a store. I bought it and another for $50 from a Habitat Restore. I plan on making an enclosure later, trying to figure out if I am going with air or flood cooling long term. Right now I am standing over the part with a can of WD40 and a shop vac. If I end up needing flood the resovoir and pump will be in the bag holder area. If not the PC and control box will go there.
This is the first real part I made with the unit:
It is a dash plate for another project - Several guys I work with went in to build a race car for ChumpCar. It's a 1987 Toyota Supra, if you want to follow our stupidity head over to www.turdbucketracing.com
The other project was a Northern Hyd branded 9x20 lathe. Picked it up cheap, but it sat for a long time in a guy's wood shop and is disgusting. Working on tearing it down, but is how it sat when I brought it home:
All this time I have a few other projects going on. I will keep the thread updated as I get stuff done.
