- Oct 23, 2023
- 19
Wow that's interesting. Never thought of going electronic but I think as a learning curve I am going to stick with the gears. It looks like I have the set like yours but the two idler gears under the main drive - I have two different sizes - it seems to work ok and can drive forward and reverse from them. It's from there down - the problem is - the cluster gear only has one gear so I will need to work out how to attach a second to it - the any other combination gears - I have small gears with a very small pin in them that could locate in small holes in larger gears pushed into a movable spindle and locked with a grub screwed ring - will try that. The biggest issue is a lead screw with no keyway.
