- Feb 2, 2013
- 3,629
i test sharpened drills in aluminum, but have never heard of the steel treatment...
maybe annealed steel? or 12L14????
I would agree with the "band saw blade break in" reply. If you look at a newly sharpened drills cutting edge under enough magnification, normally there will be striations or mini burrs caused by the grinding wheel. These will be right at the cutting edge. Drilling a soft material at slower speeds and feeds tends to wear these away as opposed to possibly breaking them when the harder material is drilled. This wearing is similar to "honing" a razor. If the "striations" are broken off, they usually take "parent" material with them which leads to premature dulling of the tools cutting edge. However,,,unless this is a high production, closely controlled situation it isn't worth the effort.Place your bet and call.
Wouldn't these burrs depend upon the sharpening method which, in turn, depends upon the manufacturer? Harder steels also form less of a burr than softer steel. I could see this practice occurring when drills were made of steels like O1 and W1. I haven't looked at HSS under a microscope but my perception is that it forms very little burr.I would agree with the "band saw blade break in" reply. If you look at a newly sharpened drills cutting edge under enough magnification, normally there will be striations or mini burrs caused by the grinding wheel. These will be right at the cutting edge. Drilling a soft material at slower speeds and feeds tends to wear these away as opposed to possibly breaking them when the harder material is drilled. This wearing is similar to "honing" a razor. If the "striations" are broken off, they usually take "parent" material with them which leads to premature dulling of the tools cutting edge. However,,,unless this is a high production, closely controlled situation it isn't worth the effort.
