- Apr 30, 2015
- 11,318
I'm having fun cleaning it up, also got the motor wires identified and re-mounted it- looks like the drum switch contacts are just about shot from running it on 110; I'm going to run it on 220 from now on just need to run a dedicated power line...I've got a bad back so things take a little longer these days.
The Rotex head uses a "double taper, Y style" collet size. I was able to pick up a couple more good used ones from Steve at Tools-N-Gizmos.com. Those collets reportedly have good grip force but they lack the collapse range of the ER styles. No problem for me.
I think I'll try a cold repair on that pulley- is there a better epoxy than JB weld? I've had good luck with it in the past.
Mark S.
Mark S.
