- Oct 30, 2019
- 199
For what it's worth/to close the loop with the group here - after further inspection of the tank, I have decided to try and track down a new 60 or 80 gallon tank that I can transplant all these parts over to.
I bow to greater experience when it comes to deflecting fragments although I still believe that some obstacle is better than none. I expect the real key would be running it a lower than spec pressure. Considering that the tank was probably tested at over 200 lbs of pressure, running it at 125 or so would likely be fine. I would certainly do so with that setup.
I found a surplus site online that has them new at a reasonable price, but the freight is the killer. I'm working on trying to find a local business that will let me have it delivered to their place (and drop it in my truck with a forklift) for $50, so that I can save $180 of the freight charge by not needing a liftgate and delivery to a residential area.
Thanks this is an option I had not consideredPerhaps you could have the tank delivered to the carriers terminal nearest you (save the $50 and the LTL freight should be the lowest possible). Find out which carrier the seller will use and see if their nearest terminal makes sense for you. They have always loaded onto my pick-up. YMMV.
