- Feb 7, 2012
- 539
It hasn't been a big deal cause I usually go in one direction only but one I get back home I'll check it outYou may be able to adjust the backlash out of your RT,Charley. The handle with the worm gear swivels in and out of gear. Can it be swiveled into gear any harder? If not,can you do a bit of filing somewhere to make it go into gear a bit farther.
If all else fails,pump the rotary table full of peanut butter. Use it when the room is fairly cold for best results.
