- Nov 25, 2015
- 8,399
I made a chuck key a few years ago, and tried to heat treat the business end. But I guess I failed, as the tip twisted under load. I chopped off the tip and remade it.
it's a 1/4" square. I want a longer one , about 12". This gets in the way of the my carriage which has an indicator attached, or the tension rod for the belt (if I take the tension off so I can swing the chuck).
The last one was made from 4130 I thought, or 4140. It was given to me by a friend. Either it wasn't , or my heat treating sucked.
What would you make a long chuck key out of so it didn't twist? Only the last 1 inch will be narrowed the rest will be probably 1/2 inch tapering to 3/8 gently then 3/8 " will be 1/4".
