- Dec 18, 2022
- Location
- Texas
I get my best results on those by drilling a hole a size smaller than I need were the point of the bit doesn't go deeper than the bottom of the slot then plunging a 2 flute end mill to depth and feeding slowly in the direction it needs to go.I need to duplicate this keyway on another shaft. The shaft mild steel, diameter is 0.625in nominal. The key dims are 0.118in wide x 0.5in long x 0.080 deep.
Looks like the original was cut with an endmill, but all I can envision is a lot of broken endmills and ruined work if I were to try this with such a small diameter tool.
Can someone please advise the proper tool and procedure?
