- Aug 4, 2015
- 291
Well, I started looking over my new dividing heads. Started with the Cincinnati (think it's a 10) anyway, it seems to ahve either been dropped (it's real heavy) or the plate brake was engaged and someone tried to run a helix with it and broke the brake arm. It's cast iron, so some proper jigging and a bit of brazing and it will be right as rain. Issue is that there is a secondary shaft under the main input shaft that has a locking sleeve on it that I can't budge. I have the locking screw out, I have tried pulling, tapping, beating, heating. It don't move at all. It does have a second half depth hole in it that I thought may be for a spanner wrench, but that didn't bear fruit either. I have to disassemble this thing to braze it up correctly. Some one already put some sort of a bubblegum weld on it that didn't hold. But near as I can tell they never bothered to take it apart to fix it right. It does have what seems to be a key in it, but could the shaft wtill be threaded and I need to approach it as a thread on sleeve? Any one in the know that would share some knowledge would be a big help here.
Thanks is advance.
Keith
Thanks is advance.
Keith
