- Feb 8, 2014
- 11,144
I am getting ready to convert my mill from a vari-speed to direct drive with a sensorless vector VFD because I have a bearing failing in the drive system and I have been wanting change it over anyway. Makes it easier to get the spindle under computer control.
I thought about a toothed belt and sprockets, or multi-V, but I can't think of a good reason to go either of those routes. Just adds expense with no benefit that I can see.
So it comes down to double groove or single groove V-belt pulleys. The pulleys will be about 6 3/4 inch outside diameter and the same size on both the motor and the spindle shaft. The motor is a Baldor, 3 hp, 1750 RPM and has a max rated speed of 6000 RPM, but I will limit it to 4500 RPM. Back gear will still be available with ~ 8:1 reduction.
I am leaning towards a single groove, B section, and a Kevlar belt.
Any thoughts?
Any thoughts?
