    Dismiss Notice
Need Motor for 44142
Discussion in 'HARBOR FREIGHT, CENTRAL MACHINERY & BUSY BEE' started by Happycamper, Sep 12, 2017.
  1. Happycamper
    Happycamper United States Active User Active Member
    25
    28
    City:
    Waco
    State:
    Texas
    -Return to Top-
    Anyone have a source for a motor for the 3n1 that won't break the bank?
  2. Ulma Doctor
    Ulma Doctor Infinitely Curious Active Member
    3,027
    113
    Ethereal Plane
    City:
    Tracy
    State:
    California
    -Return to Top-
    not knowing exactly what motor is in your 3N1, i can only speculate.
    i saw the spec's for the unit and it said 3/4hp motor.
    you may be able to use a 56frame 3/4 or 1 hp motor, (sold as the farm duty motors at HF if you are going on price alone about $150)
    using a different motor may require making or modifying the drive pulley(s),
    but don't fear mods can be easy! :grin big:
  3. Dave Paine
    Dave Paine United States Active Member Active Member
    188
    43
    City:
    Eastern PA
    State:
    Pennsylvania
    -Return to Top-
    I found a manual, may not be your specific machine.
    http://manuals.harborfreight.com/manuals/44000-44999/44142.pdf
    This shows the motor part as "YCYS7144". If this is a motor nameplate, I do not recognize the coding scheme. The part diagram shows the motor to be flange/face mounted, which makes sense.
    I would measure the existing motor mounting bolt circle diameter, thread pitch, shaft diameter and key dimensions. This will tell you if the motor is metric or imperial. I am guessing metric. The motor nameplate should state voltage and RPM.
    As Ulmadoctor mentioned, some modifications may be required to fit the motor you find.
    EBay may be a cheap source if you can find the right motor. DealersElectric is a good place to find what may be readily available.
    http://dealerselectric.com/
  4. BogusSVO
    BogusSVO United States Iron Registered Member
    12
    3
    City:
    pensacola
    State:
    Florida
    -Return to Top-
    Have you checked locally on the cost of getting the one you have repaired or rebuilt?
    you may have a bad diode or wore out brushes.
    Some of the Baldor motors I have get expensive quick, so I get them rebuilt
    Lucky I have 3 electric motor repair shops and a couple starter and alternator repair close by
    You may want to check into it.
  5. Happycamper
    25
    28
    City:
    Waco
    State:
    Texas
    -Return to Top-
    Thanks all! I was hoping to find someone that had replaced one before and would know the specifics. The motor went out several years ago and I had replaced it with one of the HF farm motors. Since I had the 3n1 bolted down to a bench, I just figured out the distances and so forth, took the mount off the back of the cabinet and bolted it to my bench. Now I am wanting to sell it and trying to figure out how to mount a motor back similar to original specs. Dave, you are right. The original motor (as I recall) did have a face mount. And Bogus, I tried to have the original rebuilt but no one would touch the Chinese motor. I guess I'll have to make a bracket of some kind to mount the farm motor unless I can find a buyer with a solid bench to put it on.
  6. Ulma Doctor
    3,027
    113
    Ethereal Plane
    City:
    Tracy
    State:
    California
    -Return to Top-
    here is a link to an IEC (metric) motor chart from marathon motors inc.
    if you know the original shaft size, you can reverse look up the IEC frame # and find an appropriate motor to replace the replacement :)
    you may have a B5 mount- 63 or possibly a 71 frame, but that is pure speculation on my part.
    here is a chart to see for yourself
    http://www.marathonelectric.com/docs/BackCover.pdf
    ch2co likes this.
  7. Dave Paine
    188
    43
    City:
    Eastern PA
    State:
    Pennsylvania
    -Return to Top-
    A useful PDF from UlmaDoctor.
    FYI, if you do not find your motor measurements in the chart, you are not alone.
    I have a Grizzly lathe, made in Taiwan which has IEC 90L motor.
    I also have a Grizzly milling machine, also made in Taiwan, which has a motor of unknown specification. The motor is typical rigid base/foot mount. The mounting holes are close to a NEMA 145, but the shaft is 3/4in. A NEMA 145 motor would be 7/8in shaft. An odd combination.
    Ulma Doctor likes this.
  8. Happycamper
    25
    28
    City:
    Waco
    State:
    Texas
    -Return to Top-
    Dave, I have bought parts from grizzly that fit the HF 44142, in particular the crossfeed nut. I think they used their own specs to make the motors just so if you wanted to easily replace it, you'd have to buy theirs. The car makers do the same thing. On most of the new cars, some critical parts are only available from the dealers. I'll just make a mount similar to the original and mount the farm motor. Thanks all!
Share This Page
