- Dec 3, 2020
- 168
Actually he's from Niles Michigan. Guy by the name of Doug Fattic, a very good guy to know. He used to go to Ukraine for part of each year to help them get set up to build bike frames. I don't think he's been there lately, because of the war. The shop they set up, where he used to teach, is in Bucha, a town over-run by the Russians, then liberated by the Ukrainians. The Russkis did break in and steal a bunch of tools, but luckily not the bike frame specific ones like the tacking jig.Authoritative info here on Acetylene vs Propane from a bicycle frame maker in Ukraine. This guy really lays the info down. He reccos a Uniweld 71 Airline torch handle for it's small size and accessible mixture knobs on top. Sounds just right for the small work I tend to do.
https://www.velocipedesalon.com/forum/f10/acetylene-vs-propane-30480.html?highlight=Propane
Sorry this is all off-topic, but if you search for Fattic you'll get a lot of info on brazing with propane. He's also a big proponent of using cast-off medical O2 concentrators instead of bottled O2. Other than the little electricity they use, it's an endless supply of free O2. Unless you're brazing with some really big flames, the typical 5 liter per minute (5 l/m) concentrators keep up just fine for brazing. There are also 10 l/m concentrators, but way expensive. When they do come up on CL (rarely) they're 4-5x as expensive as the 5 l/m ones. You can gang two or more concentrators up in parallel to get more O2 output if needed, cheaper than buying one 10 l/m.
