- May 7, 2023
- 1,417
No need for an atmospheric furnace for heat treat unless youre doing home shop work for aerospace.I have a pretty good sized cylinder of ultra pure nitrogen (about 5’ tall) that I got free. Like my other cylinders it’s stored outside the shop mostly.
Think I may be able to use it for welding but haven’t tried yet. MIG, TIG?
Maybe for my heat treat oven when I get it set up?
John
Just use tool wrap. And yes on the gas for Tig.
My dad did furnace brazing for nasa and the .mil complex from the 60s to the late 90s. I was always amazed as a kid to see the factory with no security whatsoever, but then again, no one there knew what the parts were for. No secrets, no leaks.
So I got the torch with Type A small fittings and have adapted it to Type B hose. Will I save on gas? Does this restrict/reduce the gas output?
No. Gas requirement is based on the flame needed.
I actually sold my torch setup out fear of fire and the insurance implications. Specifically that I would not be covered because my insurance does not allow welding. So if there was a fire and my neighbour's house was affected my insurance would not cover the damages.
Your caution is well placed. Many insurance companies (and their adjusters) will try to ask adversarial questions to invalidate coverage any possible reason.
However a very careful reading of the fine print of your home ownership policy tells a different story. For the sake of prudence, My oxyset is on a wheeled welding cart in my garden shed, under lock and key. One could make the argument that using it indoors might trigger the nonsense. But since that isn't in the written contract, well you know.
I have tussled with auto insurance companies 3 times, and house insurance people once, in the past. So far I have come out with a satisfactory outcome every time. My most recent one, I moved my insurance to another company and fired my broker, because of nonsense about metalworking, so I chose a company with full disclosure, that was only a small up-charge. This my first neutral result in 45 years.
Maybe this is a Canadian thing?
I don't worry about this as if I can burn my house down doing my own electrical work without penalty, welding shouldn't matter.
Hell, I even have a wood stove.
