I have took into account the backlash. Was just kind of confused on how much to expect to see when I dial in using the compound vs the crossslide dial. Also, as soon as I get home I will try and see how much error I have. This is all due to my inexperience I’m sure. Just trying to figure this thing out,lolHow much error are you seeing? Are you taking into account the normal backlash which all machines have?
If your axis screws are worn you may have unpredictable results depending on how much wear there is
Looks like your screws are imperial so 0.1" per turn or 100 thousandths
If the compound is set at an angle less than 90* (like in the pictures) the tool will move in towards the work far less than .001 per line on the dial. It will only be .001 per line when the compound is at 90*.I have took into account the backlash. Was just kind of confused on how much to expect to see when I dial in using the compound vs the crossslide dial. Also, as soon as I get home I will try and see how much error I have. This is all due to my inexperience I’m sure. Just trying to figure this thing out,lol
Dial Test Indicator. I think a normal dial indicator would be easier for this purpose. Mount a dial indicator so it's touching the cross slide, zero the dial on the indicator and on the cross slide dial, then turn the handle and see if the two agree.Also what is DTI’s ?
Sorry. Dial travel indicators.Also what is DTI’s ?
