M
Mister Ed
Forum Guest
Register Today
See I was thinking the notches were down. I can remember having a heck of a time with them ... but that was way too many years ago to remember clearly!! Thinking about the notches being up, now I understand the adjustment.Ed, notice that the contact points for the spacers are higher than the bed contact surface. If I machined all those surfaces flat, I'd have to make the spacers longer, not shorter. If I did that, I'd have
to use shims to adjust since the designed in "adjustment" would be gone.
Look at the location of the spacer contact points: outboard of the bolts. When the bolt is tightened it has a tendency to tilt the gib, which tightens the gib on the bed. The notches in the spacers
are there to clear a step in the bottom of the carriage.
What I was trying to say before was, I would not remove the spacer contact points completely, just remove enough so that they are even ... but after all wear is machine from the bed contact surface. You will want the spacer contact points machined parallel with the bed contact surface. And the spacers the same size ... or you will end up in the same boat with wear on one end.
A different twist on my thoughts above: The two spacer contact surfaces really should not have any wear (and it looks like original machining marks on both sides). Use those surfaces as a reference to machine out the wear on the bed contact surface. That will make all 3 surfaces parallel. Then you would have to determine how much to shorten the spacers. Because you did not take any material off the spacer contact points, you would still have the same level of adjustability (I think).
If you hold the gib (by hand) so that the unworn right side is flat to the bed (or surface plate), how much clearance is on the worn side? Maybe I missed that above.
Maybe Scott will have a new one laying around, LOL.
