- Mar 27, 2022
- 426
I’m redoing the bucket pins on my tractor. The tops are done. The bottoms are very egg shaped. My major dia that I measured is 1.075” and minor is 1.035. I need to make it round again. I could go up to 1 5/64(1.078) and oversize the buckets holes also or I could go big enough to put a sleeve in?
I don’t know which way would be best, I have a corded and battery hand drill. I thought about buying a mag drill but wasnt sure the if the loader arm steel is thick enough to provide enough holding power, also one arm is slightly buckled in the middle (can just make it out in the picture) and would have to flatten for the mag base.
I also wasnt sure what the best cutting tool would be. If I went with a 1 5/64” drill bit that would be really hard on the edges of the drill bit especially with it being egg shaped, i also am not sure about a reamer as it needs to go .030” larger. Maybe a tapered reamer of some sort? It I oversized it enough for a bushing a drill bit would have more engagement on the cutting face but I don’t know that I have an effective way as is to provide the force and hp to use the bit on the tractor.
Also this pin/hinge has no grease zerk. I plan on adding it to the loader arm. I don’t want to cross drill the pin a out of fear of weakening it.
I’ll attach pictures of my issue below.
