- Jul 28, 2017
- 2,373
So the Z is jumping around and the sound of the X & Y steppers is different when cutting arcs or angles? What happens when you remove power from, say, the X driver (Y still powered up), and then reverse the situation? There seems to be some odd interaction going on between the axes.
Something else I would suggest would be to write up a table of each hypothesis, experiment and result. Or, since nothing has really solved the problem, at least a list of what you've tried and why. While you may think you've exhausted a particular avenue, you may find some holes in your testing while you are writing up your summary. This has been helpful for me when working on a gnarly problem.
Are you using the sense connections on your power supplies or are they unconnected?
