- Mar 26, 2014
- 211
Good morning. I have a Logan 820 Lathe that has some bad gears in the quick change gear box. The replacement gears from Logan are way beyond my budget. I have found gears that will work but need some modifications. The thickness needs to be reduced and the bore enlarged for the bushings. There are two 16/32tooth gears and a 40 tooth gear. Haven’t received the 40t yet. I’m near Asheville NC.
Any help or advice would really be appreciated.
Thanks!
Thanks!
