Rick a new or clean fine-cut file used as a draw file will easily get you to your tolerances. It is much faster than scraping, and the equipment is in the 10$ range, not the 200$ range.
[edit] it is much easier than scraping.
[2nd edit] If you are keen to learn scraping you can get to within .005 of your goal using a mill or file and scrape from there.
