- Dec 3, 2017
- 1,911
Any further conclusions reached here? I've been trying to get mine to work with no luck too. The quick release feature is much less important to me than the secure clamping. I may have to buy an acme nut as well.
This past weekend I picked up a barely, if at all, used G0651 and the vise wouldn't tighten. The pin (215) wasn't a roll pin but a solid pin with a poor attempt at knurling to keep in in place. I could drive it down slightly and get the vise to tighten but then it would push back to the top and the vise would slip. I simply made a slightly larger diameter pin and so far it is working just fine. I should have thought about it a little more and just put a roll pin in there instead.Don't sell your bandsaws just yet ... I had the same problem with my 10x17 .. on mine there are two parts to the casting that goes around the ACME screw, the larger we'll consider the housing (214) and the smaller the offset-half-ACME nut (213) .. when my vise began to slip I considered worn out ACME threads on either the screw or the nut, but it turned out to be neither .. there is a roll-pin (215) going through the top of the housing which protrudes into the space where the nut lives, it engages with said nut when the vise handle is turned and pushes the half ACME thread onto the ACME screw .. if your vise doesn't clamp any longer, try tapping that pin down another 1/16 of an inch and try again .. as the pin wears on the casting, it'll have to be pushed further over the years .. one might be tempted to replace the wearing pin with a hardened piece of steel, but that woudl only result in the actual casting wearing down .. which is way more costly of a replacement than a simple roll pin .. hope this helps, fixed my vise issue for good ... cheers
